Pagescope Export "cannot perform" error
+ More Options
Posts
  • JR2ALTA
    • Feb 2010
    • 2030
    i have been getting this annoying bug more frequently. A perfectly normal admin login, but i try to export a copy of the address book i get "cannot perform (service?)" and it boots me out of admin mode.
    after entering 100+ plus entries, i need a backup and this is glitch is scaring me i might lose it all.
    anyone seen this?
    thanks
  • wseyller
    • Sep 2012
    • 1129
    I have seen it only when importing from a different model. Learn how to page scope data administrator and use it if it comes down to it. It is a software you download from Konica Minolta. It supports most common models.
    Sent from my Galaxy Nexus using Tapatalk 2
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      Re: Pagescope Export "cannot perform" error
      Most of the KonicaMinolta machines don't require you to log in as Administrator to add addresses so if you do your adding without being logged in you don't have to worry about being kicked out. If you do wish to login as Administrator for extended periods simply disable Auto Reset at the machine before you start as the reset is what kicks you out.
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • TheOwl
          • Nov 2008
          • 1732
          When using IE, make the following changes and see if this helps:
          1. Internet Options
          2. General Tab
          3. Click Settings with in the Browsing History section
          4. Click the option "Every time I visit the web page"
          5. Ok
          6. Ok
          7. Reload the web interface of the device
          The us know if this solves the issue.
          • emujo
            • Jun 2009
            • 3009
            Check for incorrect s/n info in System1, and errors in the address book. You might try updating firmware and ensuring you are at "functionversion 3" through soft switches. Page Scope Data Admin does work a little bettter when it comes to manipulating the address books, but if there is a corrupt file it won't update in this program either. Emujo
