Email configuration not found in menu
  • julien.boileau@gmail.com
    • Jan 2025
    [Misc] Email configuration not found in menu
    Hello,
    Our company just bought a BizHub C203 from another company that upgrade to a bigger printer.
    I have setup everything to use the printer over the company network.
    So, we can scan, fax, copy and print.
    I just have 2 issues to solve to finish the configuration.
    We would very appreciate if you can provide us some instruction to explain were to change those 2 values that are reflecting the previous owner information.
    Thanks in advance!
    Regards,
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: Email configuration not found in menu
    Get the IP addy of the machine and go to the pagescope page. Sender email addy is either the administrator's email set under System Settings or a specific email in the smtp setup page. The email subject is under the address book menu, it will say subject.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
      I have use the pagescope web interface to configure most of the function of the printer. I already have change in the Maintenance Tab->Machine Setting->Admin Email Address and that doesn't replace the from address. I'm going nut about this. And for the subject, I have also tried to change it in the store address tab and it's not working also. Thank for your replie!
        Also, I have changed the email address in the Network tab->e-mail setting->email tx (smtp). And it's not using this email also.
        • Kidaver
          Ghoulscout
          • Apr 2011
          • 912
          If it's not using the admin's email address like I said you might check the sender address on the smtp set up page. Might also look for email addresses in the POP3 setup. As for the subject you might check check under fax settings then under Headers and Footers....being it's a fax to email thing...
            I've been trying to fix this since 2 days. I have tried a lot of things. I have change the email under POP3 and i'm still having the old email. I have look in all the menu to find the old email address and i'm not able to find it. Thank you for help!
              I have exported the machine setting in a .dat file. Do you know an application that can I use to read this binary file ? If an application exist to read that file, I can use it to see all the setting and maybe find the old email address that I want to change. Change it and after import it to the printer with the new email address!
              • scottybbb
                • Dec 2010
                • 126
                At machine try these tabs.Admin. settings-Admin.\Machine settings-Admin. registration.Also make changes under input machine address tab.
                • SmellsHot
                  Head Tech
                  • 512
                  How about starting fresh and do a network settings clear.
                  Everyone has the right to be stupid. Some people just abuse this privelage more than others
                  • speedtek
                    • Apr 2013
                    • 46
                    On the Fax/Scan screen click "Communication Settings" and see what the from address is there. If it's not correct change it there, then go to Utility/Counter -> User Settings -> Scan Settings -> And "Default Scan/Fax Settings" to "Current Setting". If it's already set to it, select it anyway and then hit OK. This will save your current scan settings (including the "from" address).
                    I've seen it sometimes where the "Current Setting" was selected before the from address was set, and it messed everything up.
                      Thanks I lot! This solved my problem! I was looking for that! Again Thanks you!
