C253 faded image
  • Darren King
    copiertech
    • 652
    C253 faded image
    Hey everyone:
    I am working on a C253 that has me scratching my head. It is producing faded images (prints and copies). When I do an initialize and stablize, copies and prints look good, as soon as you either do a gradation or power cycle the machine it starts producing faded images again. This is affecting both colour and black. I have tried transfer belt and roller, adjusted printhead skew (because they were way off). All settings appear OK, I compared with a C353 I have in shop also.
    Any suggestions would be appreciated
    Darren
    I have attached samples. The first set are after initialize/stablize, O is for original C is for copy
    Second set is after gradation and power cycle.
  • ck1
    • 485
    Re: C253 faded image
    I also facing this issue... the other technician said PWB MFB ( no change yet ) . i try rewrite firmware still same
    • fishleg
      • Mar 2009
      • 426
      Worked on millions of these your copies look pretty normal to me. The first thing I would do is clean the optics make sure you use decent paper for setting up the gradation as a copier I always up the density by 1 as its default. If your imaging units are not perfect when you setup the gradation or the optics are dirty you can make the image super faint like this.
      So I would
      check your optics
      check the imaging units
      use decent paper and setup gradation etc
      Then if its still faint I would initialise stabilizer and leave it on zero's half the machines I've seen the copy quality is actually best this way.
      • RRodgers
        • Jun 2009
        • 1947
        I've said it once before and I'll say it again, I NEVER expect a copy of a print out that just came off the machine to look any good. This goes double for one of the test prints.
        • Darren King
          copiertech
          • 652
          I didn't say that I cared about the difference between the print and the copy. I said, after initialize/stablize prints and copies look good. After power cycle OR gradation copies AND prints are faded. (please see samples)
          • ck1
            • 485
            I post tihs issue before. but i think their not understand what i said too .I will try swap the NVram . Did you try it before change MFB ?
