C351 Gear grinding noise
  • nmfaxman
    • 1702
    No failure codes, but jams.
    Everything seems to turn ok.
    Check IUs, fuser paper feed and waste augers including ITB.
    Something I am missing?
    Thanks for any thoughts
    Yes I have the manual.
  • kronical
    Kronic Copier Ninja
    • Nov 2009
    • 230
    Re: C351 Gear grinding noise
    Jams, with a grinding noise?
    Make sure the machine shows the correct size and orientation. Sounds like a size mismatch jam.
    • nmfaxman
      • 1702
      Noise starts during warmup.
      • 907tec
        • 434
        Where is it jamming? Have you checked the "tear-drop" gear assembly above the fuser? There is a small set of white gears with a "tear-drop" shaped plate just above the fuser assembly. Usually, there is a spring attached to the gear assembly pulling it downwards, but the mounting post likes to snap. Check to see if that spring is still attached, or if the spring mounting post is cracked/bent.
        • nmfaxman
          • 1702
          Turned out to be IU waste toner auger.
          Customer put DI200 toner in Color machine.
          Cost her $300.00 in repairs.
