C6501 C-0213
  • NiklasT
    • Apr 2013
    • 7
    C6501 C-0213
    Hi Copy friends
    I have a problem with C6501 Code C-0213
    I changed Exit roller assy. But i can not see the motor turning anyway.. (The paper jam every time)
    Do you think i must change AC DRIVER CARD??
    Niklas T/ Sweden
  • Setright
    FSS / SPM
    • Nov 2008
    • 247
    Re: C6501 C-0213
    Hejsan!
    Exactly how much did you replace? There are some one-way clutches hiding the gears, and these might be defective.
    You can run the motor using I/O check mode, and if you also remove any finishing equipment you can see if it actually is turning.
    • NiklasT
      • Apr 2013
      • 7
      Re: C6501 C-0213
      Hi Setright
      I checked the motor in I/O Mode. The motor was not turning at all.
      I also checked the one way cluthes and also replaced 2 of them.
      Nothing worked. But after i changed the Ac Drive Board. The machine work... Jippi
      I took the Ac Drive Board from a C6500. It was the same board as C6501 (A03UH52002)
      Thank you for the reply
      Niklas T/Sweden
      • JustManuals
        • Jan 2006
        • 9838
        Re: C6501 C-0213
        Paul@justmanuals.com
