C224jam
  • amigoami
    [Jamming] C224jam
    C224 jumps exception paper jam 99-01
    From one or two cartridge
    Separate test print lost ten
    Paper will intermittently stop before synchronizing
    Replace the synchronous clutch is not valid
    Invalid update firmware
  • Gaffers01
    • May 2011
    • 334
    Re: C224jam
    Originally posted by amigoami
    C224 jam Code 99-01
    The paper sporadic sent synchronous roller stops
    Separately from the of ten blank page test print from time to time
    Updated firmware is invalid
    The first with the second cartridge will
    How and solutions
    To replace the MFP version or PRCB
    If not,
    Board replacement with re-machine no longer a
    You What?
    • Avskrap
      Partner in crime
      • Jul 2011
      • 160
      Re: C224jam
      I suggest not using Google Translate.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: C224jam
        if its from large capacity tray 3, its because the piece of crap 1 way gear on the transport roller falls apart.
        It can be held together and prevented from failing again by using the spacer shims in 2 x "support kit" used on feed rollers.
        • JustManuals
          • Jan 2006
          • 9838
          Re: C224jam
          Paul@justmanuals.com
