Black Toner in C500
  • rindraintsoa
    • Sep 2010
    • 55
    Black Toner in C500
    Hi all,
    I have a strange problem with my Bizhub Proc C500 Machine. As you can see in the attachement, I have a black strip on the edge of my printout, tried to swap the black drum, having the samr prob, swapping the develmopping Unit with Cyan Dev Unit, I got a Cyan strip. I have tried to make auto gamma sensor adjustement and get error code SC-29-06. I have also tried to use another working Black drum but the problem is always comming out. I am desperately looking for another solution. But till now no solution.
    Would you please advice me what to do ?
  • tech51
    • 846
    Re: Black Toner in C500
    Looks like a charge problem. Try swapping the charge coronas between the colours and see if the fault moves.
    • rindraintsoa
      • Sep 2010
      • 55
      Thank you for your advice but still having the same prob, I have swapped all drum, charge corona, developping Unit and also cleaned the led erase unit but the problem is always the same, any other suggestion?
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          Connector in the back of the machine that connects to the black charge corona may be bad. Sometimes they have visible burn marks or even have seen a small hole burned thru the plastic. Sometimes they look ok but short to ground.
          • rindraintsoa
            • Sep 2010
            • 55
            Thanks guys for your help, the problem is solved now, I have made 3 times toner refresh mode and after in 36 mode Drum potential auto adjust, and the strips had gone.
