bizhub c 360
  • thuo
    • 155
    bizhub c 360
    hi
    i have a bizhub c 360.when switched on it doesn't go thru stabilization shows warming up for a few seconds then goes to ready mode.when a document is sent to the printer it goes to the que. but cant print.
    any sugestions
    thanks
  • emujo
    • Jun 2009
    • 3009
    Re: bizhub c 360
    It sounds like on or more of your PM parts (IU/X-fer belt/Fuser) has reached the life stop point. We had this when the tech installed the PPLM firmware, but didn't set the dip switches/life stop settings correctly. MFP would come to ready, but copy/print jobs would delete automatically. Look at your consumables under user mode to verify this and either replace the affected units, or install the PPLM firmware. Emujo
    • JustManuals
      • Jan 2006
      • 9838
      Re: bizhub c 360
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        Re: bizhub c 360
        bet your running that C version firmware that hides consumable life reminders
        Upgrade the firmware and it'll tell you what it wants.
        • thuo
          • 155
          Re: bizhub c 360
          I have upgraded the firmware but no change. what amazes me is when i disconect the fuser unit conectors the machine does not show any error codes nor does it run stabilisation. machine just goes to ready mode.when job is sent to the printer its held in the printer but cannot print.
          • thuo
            • 155
            Re: bizhub c 360
            • Max
              • Oct 2011
              • 561
              Re: bizhub c 360
              Reset the copier back to factory defaults. Its a bit drastic but as long as you make a back up of address book you will be fine. I have done it a couple of times for various other problems worked every time.
