Ineo 751 Network Menu (5) on panel is not showing
  • Pinoy_Tech
    • Feb 2010
    • 47
    #16
    Re: Ineo 751 Network Menu (5) on panel is not showing
    Hi to all!
    I received my ordered CF card today ($400) and tried to set it to the machine where I been cannibalized (our showroom machine), but upon inserting it, the machine is telling me about licensing issue. When I take a look at our service manual, it requires some procedures to be done in order to remove the license notice, but this is a bit disturbing as I think.
    Then, it came to my mind to revive the old Cf Card which I have mistakably formatted before on ordinary windows. This time I must be very careful to all my steps because I don't want to damage another Cf card.
    To be able to revive the old Cf card, I need to copy the entire image of the newly ordered cf card to replicate it to the old cf card and I knew it must be done through the help of softwares. Luckily it is very successful!!!
    Then after I rewritten the image to the old card, I selected all files and deleted it so that there will be no files will remain on the revived card. This time no formatting command anymore .
    Fortunately, I have made a previous backup copy from my other working Cf card which I have already installed on the other running machine before, but this time the machine is far away from me so it is my luck that I have the copy of the entire files on my personal usb. Then I simply copy/paste those files towards my revived cf card. Guess what, all things work fine!!! The good thing is, the machine is not showing about the licensing isssue anymore. At last, got something additional knowledge from my mistakes.
    Here is the software I used. Note that the "DiskTool 0.1" which is just placed somewhere in this forum is also working fine but it takes time to finish the entire 256MB card while the link below takes about a minute or two.. Credit to all....
    Best regards,
    576Pinoy_Tech
    Tools for OSForensics - ImageUSB - Write an image to multiple USB Flash Drives
    • princef18
      • Jul 2011
      • 37
      #17
      Hi,
      I'm not sure about this model. In the service mode under State confirmation you should be able to find an option to format the CF card. I had a similar problem where the I formatted a hard disk and it would not work on the machine. Once I formatted it in the service mode, it worked fine.
      Hope this helps.
      • Pinoy_Tech
        • Feb 2010
        • 47
        #18
        ^ CF card is use as a booting SYSTEM of the machine itself. Can't run the machine alone without CF Card first because the initial kick will start from there. So, we must fix first the card before we can access to the "state confirmation menu". However, there is other way to do that by simply inserting the other running CF card, then remove the card when the machine is already initialized (NOT REALLy RECOMMENDED because there will be a big possibility of distructing the CF card files while the machine is at ON condition). For curiousity reason, I did it once but in some point it will hung-up because there is a tandem work between NVRAM & good running CF files. On the other hand, on state conf menu, I did not see any CF card formatting command. Only memory/HDD formatting is there. Tnx...
