C35 "wrong image unit installed"
  • Gift
    • Mar 2011
    • 2458
    Hey there,
    got some reset chips for the C25/35 series Image Units. These works flawless for the little C25 but does cause an permanent error message like "wrong image unit installed" if you chip an IU at the C35 (or C35P). Function is still OK and life counter gets resettet though, but the message is a bit disturbing. This limitation is described with the chips but I'm curious if there's either a way to supress the message* or if there are improved chips out there that doesn't trigger the message.
    * not looking for "use a new OEM unit" reply
