Greetings, thank you in advance for any help...
Finisher fell over in a move and broke output trays and bent the long metal roller shaft at mouth exit of upper tray...
I disconnect the finisher from bizhub c550 and power on to use without the finisher but the screen gives me error saying: "The part indicated by (black arrow) is open, please be sure that it is properly closed." The arrow points to nothing and I can't go to administration or service mode with the error up...
I have another good FS608 finisher in another part of the building so I wheel it over and connect it and this bizhub c550 is happy again but the other c550 no happy...
How do I run this thing without the finisher? I can get into administration and/or service mode but I see no settings to enable/disable finisher... are there jumper settings I am overlooking or something? Do I need a paper route re-direction part?
Thanks again,
David.
Thanks again,
David.
