C250 with C2552 Code
  • Solotime
    • 223
    Have a c250 that had a C2552 code. Went out yesterday and installed new Cyan IU and also had to replace the drive unit for the I/U's because the cyan IU had locked up and stripped a gear. Customer called this morning with C2552 code again? They opened and closed the door and it is running again. Any suggestions? It is a way out of town account so wanting to get info before going back.
    Thanks,
  • JustManuals
    • Jan 2006
    • 9838
    Re: C250 with C2552 Code
    Paul@justmanuals.com
    • avecosat
      • Jun 2012
      • 303
      Change back the UI, I spend the same and until changed again by another unit was still out the error.
      • HoonBoy
        • May 2011
        • 130
        Let them try too change toner first, often it will solve the case. Sometimes it's empty but not giving a toner empty indication... Could also be that something is wrong with the toner supply....
        • blazebusiness
          SanDiegoCopierRepair.com
          • 1250
          Agreed....I've seen that happen due to toner. Start with a fresh toner. If that doen't fix it.....diagnose toner supply problem or IU problem.
          • DigiMan
            • Jan 2013
            • 262
            I would agree with previous answers,usually(as far as ive seen)when trying to add toner manually and theres a problem with it the procedure keeps going for 20-30 seconds while no problem results in 10 seconds more or less.You could try to take a look at the hopper section by pulling out the toner,theres a triangle plastic beeing pressed by a spring,its a long shot but you could try to check if its broken/out of place.
            Hope i helped.
            I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
            • Solotime
              • 223
              Replaced the Cyan I/U again yesterday morning. So far it has been running. I suspect that when I installed the original new unit, and since the gear was damaged and not turning the I/U's that somehow the initialization process got screwed up.
