BH-C-253 needs time after scan from platen
  • Hansoon
    • Sep 2007
    • 3389
    BH-C-253 needs time after scan from platen.
    Have little practical experience yet with this machine. The first one I have we got from a reseller. Didn't play with the settings yet but I noticed that this machine copies normal as long as you are using the ADF but when you make copies from the platen you have to wait for the copy to come out of the machine before the print button to comes back to ready for the next copy from the platen. Is this standard or did someone play with the settings.
    I have ofcourse all manuals but am a little under pressure cause the machine must be demonstrated early Monday morning and cannot risk to mess up settings or else before.
    Thanks in advance for any help.
    Hans
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Re: BH-C-253 needs time after scan from platen
    Hans
    Very interesting.....not sure if copying on the glass the machine requires the job to be completed before it will let you scan again, never paid much attention to that before. If it is a setting---you can set the machine back to factory defaults rather than digging around for the setting. I have seen on this model when the default from the glass is set to auto sort/offset that it annoyingly asks you if you want to load next original. Maybe a memory issue--Is the hdd enabled? Sometimes the reseller wants to get rid of the password function and initializes the machine in service mode which uninstalls the option boards. Let us know what you find.
    • paulrid
      • Nov 2011
      • 206
      Seen this on c252 or c352 can't remember which one but I'm sure it would be the same as a c253 there is a setting to turn this feature on/ off it will be under "utility" then user settings, sorry you will have to look around for it unless I get to a machine before you.
      paul.
