Bizhub C-8000
  • Saghir377
    • Feb 2013
    • 47
    [Misc] Bizhub C-8000
    Hi, hope you all fine
    Dear i have one machine Bizhub c-8000 its having problem in thin paper MO 90 gsm to 150 gsm and some less in GO same thickness
    Front side print came like some body drop water on print If it is duplex 2nd side came normal. Maximum on black but same problem on all colors 200 gsm to 350 printing normal Wood free paper no problem.
    I replace Lower belt unit and Roller assy 2nd transfer unit but same nothing change Some time its printing normal but with in 500 copy's the problem came again.
    I have some sample with me please check and guide
    Thanks to all for cooperation.
  • kalindd
    • Jun 2008
    • 192
    Re: Bizhub C-8000
    Did you try to activate the thin coated paper mode?
    Access [Utility] -> [02 User Setting] -> [03 Common Setting] -> [Next] -> [Prior Paper Type],
    [Thin Coated]
    then
    [Utility] -> [02 User Setting] -> [01 System Setting] -> [03 Paper Tray Setting] -> [81-105gsm Coated], where [Standard] (default) and [Thin Coated]. This setting is available for each tray.
    I would recommend you to change the Fusing stability priority
    [Utility] -> [02 User Setting] -> [03 Common Setting] -> [Next]-> [Next]-> Best quality and Fusing stability ( or something like)
    I hope this helps.
    Good luck
    • JustManuals
      • Jan 2006
      • 9838
      Re: Bizhub C-8000
      Paul@justmanuals.com
      • methogod
        • Dec 2008
        • 921
        Re: Bizhub C-8000
        what does the machine have after the 2nd fuser? water decurler?
        if so may need a physical adjustment...
        • DigiMan
          • Jan 2013
          • 262
          Re: Bizhub C-8000
          Zero experience with this model but i guess you could try to stop the machine while printing to maybe pinpoint when/where the problem occurs?
          I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.
          • KMnyafayce
            Bradley
            • 45
            I have 5 in my terrority and struggle with this same exact issue. Most if the time if the problem is after 2nd xfer bur before fuser (via panic stop) its a paper that the machine just doesn't like. C8000 is very pick with its lighter weight paper 110gsm and below. Espicaly uncoated stock.
            • methogod
              • Dec 2008
              • 921
              Re: Bizhub C-8000
              Try a silk coated, or use a MOHAWK brand coated.
              If we are running something that think we dont run it on the C8000 but the C6501 or a slower model.
              We dont get many requests for less then 80# gloss.
