Bizhub C250
  • coyotee
    Bizhub C250
    Hello everyone! hope you can help me.
    We have K bizhub 250 in our company and attached to LAN. There is a problem with scaning, we couldnt figure out how to get it to work. First here is our configuration:
    1. http://shrani.si/f/1E/w9/3ps9Rg7o/screenshot5.jpg
    2. I am gettin these errors:
    TX(NG)(ED09C8)
    TX(NG)(ED09C6)
    3. http://shrani.si/f/2X/B0/1OI8fpqG/screenshot6.jpg
    on this screen I don`t exactly know in what form should I put destination path, and this password cant be changed...
    Please help me!
    Thanks in advance
  • ni311
    • May 2008
    • 658
    One touch name - the name of the button that will be shown on the touch screen
    IP Address - the IP on the PC you want to send the files
    File Path - only the name of the shared folder (as you'll seen when you'll access from a different PC)
    User name and pass - for accessing the shared resource.
    I'm not sure why you cannot change the password. Is the field disabled? or is not saving the new password? Give us more details.
    Konica Minolta Error Codes - Explanations and Solutions
    • Frostwolf
      • 71
      On the screenshot6 fill in the following. SMB (expanded slightly on Ni311's reply)
      One touch name _ (Name of button)
      Destination _ (input IP address or computers name)
      File path _ type "Scan"
      User Name _ The login name of the computer user (admin account)
      Password _ the login password (it always shows **** even without a password)
      set PDF or Tiff
      Set mmr for better compression.
      Now at the computer. Goto C drive, and create a folder, Name it "Scan"
      Right click on the folder and share it, with allow users to change my files. If sharing is not setup, tell it to just activate sharing, windows will share everything if you let it do it.
      Hostname doesn't always work. IP will work as long as the ip never changes.
      The codes (ED09C8)(ED09C6) are in the network scan owners manual. If I remeber right the one with the 6 is Destination not available, 8 may be username or password.
      Rarely will you find the services for sharing shutdown, and simple file sahring turned off. How to configure file sharing in Windows XP
      Good luck
      • xcopytech
        • Aug 2006
        • 1794
        Just follow Frostwolf instruction and if you have firewall on PC just set exception for machine ip address.
        Regards for Slovenia
        • coyotee
          still nothing
          Hello Again!
          I have tried your settings and it is always the same. I am getting error:
          ED09C8, The specified folder does not exist.
          on bizhub I get following error: communication error occured.
          I made new Folder named Scan and share it.
          Firewall is set off.
          What could it be??
          • coyotee
            Solve the problem
            Thank again guys. It works now perfect.. After almost 2 years of owning Bizhub 250.....
            bye, bojan
            • sargents27
              What was the answer to your problem?
              Hi - you never said what you did to actually solve your problem. I am having the same problem with a 250. I have already tried the Scans shared path but I am still getting the ED09C6 error. I shared the folder with 'everyone'
              I know the IP address is correct so I'm not sure what else to look at?
              thanks for any help
              • Stirton.M
                All things Konica Minolta
                • Oct 2009
                • 1804
                ensure that the folder shared has the allowance to also write and change files for those scanning to it.
                the file path is ONLY the name of the folder, so ensure you do not put anything more than the shared folder's name.
                "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                ---Groucho Marx
                Please do not PM me for questions related to Konica Minolta hardware.
                I will not answer requests or questions there.
                Please ask in the KM forum for the benefit of others to see the question and give their input.
