Actually I am wondering. I was told you get three attempts. I have never failed three times yet but what happens when you do. How do you get it reset. Does it reset after a period of time or does someone higher up have to manually reset it.
Sent from my Galaxy Nexus using Tapatalk 2
After you fail 3 times, you have to contact the NSA and get them to unlock your account so you can try again. They will let Konica know. Ever notice how as soon as you post something it has several views? N S A
I've failed 1 test 4 times in a row. It was the one that has to do with Quark. After the 4th fail I sent them an email complaining that I'm SURE there are errors in the test because I noticed I kept getting the same questions wrong. (even thought I found the correct answers in the workbook) Anyways, when I went to take it the 5th time it popped up a warning that said that this was my last attempt, after that I'd have to get my manager to reset it. They can be a pain in the @$$ sometimes. But I'm 85% done the Outward Master Color section.
Currently, the students manage to cheat even in the course of online learning. The development of technology helps students find more sophisticated ways of cheating on assignments and exams.Why Do Students Cheat on Assignments and Exams Although teachers and trainers are trying to deal with the problem of deception, their efforts in most cases come to zero, so that students continue to cheat in different circumstances and for a wide range of reasons. Therefore, it is important to analyze why students usually cheat on assignments and exams.
