Bizhub 200 Image keeps migrating to the right
  • cap0319
    • Oct 2012
    • 34
    I've never seen this before so I wanted to post here looking for a solution.
    A customers bizhub 200 prints and scans keep migrating by 1/4 of an inch to the right after each successive print.
    so 5 copies of 1 page have the last copy image nearly cut in half.
    anyone encountered this before?
  • mo0651
    • 1054
    Re: Bizhub 200 Image keeps migrating to the right
    Registration clutch....call for service.
    • Don N.
      • Nov 2011
      • 409
      Depends on direction of paper... If running paper 11" from machine front to back, yes, reg. clutch. If paper is running 8 1/2" wide, (in old "R" direction) the only time I saw image travel was on a Sharp/Xerox with laser running too slow. This machine would probably code before that happened.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • SmellsHot
          Head Tech
          • 512
          he said "scan" too everyone
          Sep pad?
          Everyone has the right to be stupid. Some people just abuse this privelage more than others
          • Don N.
            • Nov 2011
            • 409
            Missed that. Scans would not involve the printer. Prints would not involve ADF. Clarification needed. If SCANS, obviously adf reg. roller/1-way bearing or timing switch.
            • Darren King
              copiertech
              • 652
              If the paper is running SEF "short edge first" and the image is drifting it likely needs "Org. Width Detect Adjust" performed in service mode.
              If paper is running LEF "long edge first" then it is most likely the registration clutch.
              • Hansoon
                • Sep 2007
                • 3374
                Don't know why one always has to guess the critical details. Useless to answer the thread starter with so incomplete information. The information provided is just above the level of "My Copies Are Not Good What Can I do"
                Hans
                • JR2ALTA
                  • Feb 2010
                  • 2030
                  Hans
                  I've been clueless before, but mercy, posting a registration issue without first replacing the registration clutch?
