C-8000 print out patchy
  • sasa12u
    • Nov 2011
    • 39
    Hi all,
    Anyone have encounter patchy on print out where i change all the consumable which as 4 new starter,4 new drum ,4 new charger unit,new 2nd transfer unit,new 1st transfer belt,but still can't help,any suggestion???
    Thanks,
  • JustManuals
    • Jan 2006
    • 9838
    Re: C-8000 print out patchy
    Paul@justmanuals.com
    • RRodgers
      • Jun 2009
      • 1947
      Reset counters and ran adjustment
      • sasa12u
        • Nov 2011
        • 39
        After i change the consumable,i already done up the counter reset and run adjustment but the patchy stil there.
        • sasa12u
          • Nov 2011
          • 39
          Any other suggestion.Thanks
          • remati
            • 149
            how about the fusing parts? (counters)
            lower fuse belt ... upper fuse roller assy...
            and how are the internal print test ? test chart 62.. are they bad? too?
            Originally posted by sasa12u
            Hi all,
            Thanks,
            • sasa12u
              • Nov 2011
              • 39
              Fusing unit i also chg up a new 1,but stil can't solve the prb.the pathcy come out once the customer use somthg like matt paper 260gsm
              • perdana
                • Jan 2008
                • 62
                Please check black mylar Guide at Main transfer roller, or remove the mylar guide if bent or tear.
                • sasa12u
                  • Nov 2011
                  • 39
                  Hi Perdana,
                  can show me the picture of mylar u mention or itz at 1st tranfer section,or developer section?thxs
                  • Konicoz
                    • Jun 2013
                    • 62
                    is it possible to scan image and post it on thread - try test copies from another tray or on normal paper and in test mode -could help with diagnosing fault
                    Hey what ya doing? - just screwing around.
