Konica Minolta C253 DF-611 Jams
  • johva
    • 48
    Re: Konica Minolta C253 DF-611 Jams
    Problem solved. After all the time we spent on this bizhib C253 swapped DF-611's 2X, replaced the PRCB still no improvement. We went back to square one. Can't be doc feeder, the boards are OK. We unplugged the ADF and checked the wiring and one of the pins on the female plug was disconnected. Put it back together and now we have a working doc feeder. I want to thank all you guys for your input. Sometimes we miss the most obvious. Thanks again, Johva.
    • Hansoon
      • Sep 2007
      • 3389
      Thanks for the feed back.
      Wire came of the pin or did the pin slip out of position?
      Hans
      • johva
        • 48
        Pin slipped out of position.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          #19
          Wow, I forgot about that. That was a common problem on the 2510's.
