Di 2510/3010/3510
  • copycommerce
    • May 2008
    • 65
    Di 2510/3010/3510
    Hello ,
    Im i a need of a help,so do someone knows what kind of resistor is located in the imaging unit of Di 2510? I mean the values of this resistor.I recently cuted mine and now evrytime i turn off and then on the power switch, the machines says "Pls install imaging unit"
    Thanks in advance.
    I just have found the need info in google
    Resetting Minolta Di2510-Di3510 IU/PC Counter:
    Has a Resistor instead of the traditional Pico fuse.. The value is 10k ohms - 1/8 watts.
    Just wanted to pass the info along to fellow techs.
  • ck1
    • 485
    this machine not need fuse to blow. just go in to technical mode. find the counter look for Iu life ,then clear it. the sign will clear off . try it
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      Yes, what he said, and if your drums and developer are of good quality, you should get around 180,000 to 200,000 before you have to replace.
      • mjunkaged
        • 384
        It MIGHT end up being that easy, or......
        It may be a bit more complicated to get a message to go away. On my NEC branded models at least (hadn't gotten a chance on the other 3 brands), You need to run the auto toner sequence, change the developer (and the developer unit every 4th time) , drum unit, and then if you don't do the whole toner calibrate-counter reset-door open close routine, it will STILL bug you to replace photoreceptor.
        Even when you do the sequence right, it doesn't always work, sometimes I had to cycle front or main power for it to 'take'.
        I remember this being one of those sticky wickets that could go either way because I did it so seldom, say , once every 4 to 8 months!!!
        Needless to say alll is done inside tech mode.
