Hard Disk location on C250, C350 and C550
  • onie
    • 32
    I'm not sure if the C250 and C350 have hard disks but pretty sure a C550 does. Where would it be located? Can anyone tell me what panel(s) to remove to expose the hard drive?
  • JustManuals
    • Jan 2006
    • 9838
    Re: Hard Disk location on C250, C350 and C550
    These Parts & Service Manuals can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • johnyb
      • Feb 2011
      • 167
      Its on the controller.
      you need to remove the back panels.
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        on the c550 its hidden by the printer control board cage.
        you do not need to disconnect and remove the printer control board its cage swings out independently if the correct screws are undone.
        C350, cant remember, too long since i worked on one.
        C250, cant remember either, but it wont be hard to find after the rear cover is removed.
          • 14812
          On the C350 the HDD was an option, so, it may not have one. C250 will be behind the rear cover.
          • TheOwl
            • Nov 2008
            • 1732
            After removing the rear panels on the machines, you then need to remove the access panel on the shielding box which also contains the MFP board.
            On the C250, it was on the right hand side of the shielding box as you are looking at the rear of the machine.
            C350 had the HDD with the MFP board from memory.
            Depending on where you are, HDD's were optional on both of these machines. Some countries did decide to make them mandantory though by the country distributor sending HDD's when you ordered the machine.
            • onie
              • 32
              Thanks for all the helpful information. Much appreciated.
