konica buzhub223 the device is not supported 20002
  • gogi100
    • Jul 2011
    • 18
    [Error Code] konica buzhub223 the device is not supported 20002
    i have konica buzhub223 and i'm trying that configure konica export logs. i used konica's software log management utility. i registered my device and when i go to menu of device(log management settings and when i try enable log reception from this device.i receive message
    the device is not supported. 20002
    my konica buzhub 223 have not internal hard disk. i don't know where's problem?can i export logs from my konica somehow?
    thanks
  • emujo
    • Jun 2009
    • 3009
    Re: konica buzhub223 the device is not supported 20002
    Can you be more specific as to the KM program you are using??? Never heard of the "log management" utility ( only been with KM for about 5 years so may be before my time). If it's really a Page Scope product you will have to update as new MFPs are not supported by older versions of PSDA. Emujo
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • gogi100
        • Jul 2011
        • 18
        log management utility is part of page scope software data administrator with device set-up and utilities.sorry can you explain your shortcut MFP, KM, PSDA.
        • emujo
          • Jun 2009
          • 3009
          KM Konica Minolta
          PSDA PageScopeDataAdmin
          MFP...if I have to explain this then there is no help for you. Emujo
          • gogi100
            • Jul 2011
            • 18
            sorry, do not be angry. i just ask you. log management utility is plugin for page scope software data administrator. can you help me that i solve this problem?
            • emujo
              • Jun 2009
              • 3009
              when is the last time you updated your version of PSDA?
              • gogi100
                • Jul 2011
                • 18
                my version of psda is 1.0.05000.09131. i download this version from site of konica
                • emujo
                  • Jun 2009
                  • 3009
                  PSDA is up to date, however I don't see anything about log management as a plugin..See if you can find a current version of the plugin you want..
                  • gogi100
                    • Jul 2011
                    • 18
                    current version Log Management Utility V1.2 (version 1.2) that i use
                    • emujo
                      • Jun 2009
                      • 3009
                      Took a little research, but, the audit log is stored on the HDD, BH223 does not have the HDD standard. Install HDD and the utility should work. Also, there is an updated version that works with Windows 8. Emujo
                      • gogi100
                        • Jul 2011
                        • 18
                        as i thought, first i must install hdd in my bizhub 223 that i can use log management utility.
                        thanks
