Di551
  • skbarga
    [Misc] Di551
    We have a Di551. The Screen Panel has been changed via Key Operators mode, so now none of the screen buttons work. Can get into tech mode, but that is as far as we can go. The screen buttons are way out of wack or off track. We have swapped out two other Di551 panels, hoping alignment w/buttons would return. No Fix. Is there a trouble reset for the panel? Please help.
    Thank you in advance,
    Sheila
  • Luther
    • May 2006
    • 682
    Re: Di551
    1] LCD Control Panel Adjustment
    Enter the key operator mode and select 10" Touch
    panel adjustment" to adjust the LCD touch panel.
    *If you cannot select the touch panel adjustment
    mode pressing any numeric key after entering key
    operator mode will take you directly to 10" Touch
    panel adjustment".
    • skbarga
      Re: Di551
      Thank you Luther. I will try this.
      • JustManuals
        • Jan 2006
        • 9838
        Re: Di551
        Paul@justmanuals.com
