biz C6000 L error code C2814
  • remati
    • 149
    hello people
    code falls a lot of times in a day C2814
    (......I have alraedy change the color regist sensor assy)
    any ideas ?
    thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: biz C6000 L error code C2814
    Paul@justmanuals.com
    • Konicoz
      • Jun 2013
      • 62
      ganna ask silly questions, but what's the condition of K drum and dev unit, is dev unit tight and is T/B in good condition, have you tried adjustments and now I'm ganna shuttup
      Hey what ya doing? - just screwing around.
      • igorp86
        • 16
        I would suggest to change developing unit K and developer, is shutters on color reg assy opening and closing properly?
        • 1FRY1
          • 51
          It's a common problem with 6000/7000
          no fix as far as I know from KM
          I have had some success from doing a full CQ setup with a GOOD QUALITY PAPER
          Problem can disappear for months then return again.
          anyone with a definite fix for this will be a superstar.
          • lucky13
            • May 2008
            • 125
            Wanted to update on my 2814 issue.
            Code can be reset for some time by the following
            Reset code by turning off main body
            Enter tech rep mode asap once engine is back up
            Go to system settings
            Change dip switch 11=0 to a 1
            Run auto gamma
            Change dip switch 11=0 back to 0
            I noticed like others my bias number for black was at 250 and would not change. Tried running several hundred test print 53 at 255 still no change. Tried another drum and still no change, swapped dv units with cyan and ran auto gamma and bias numbers changed. Moved units back in correct position and black bias now changes with each auto gamma.
            I then made these changes to hopefully correct the issue going forward
            Set ac bias fine adj and toner density fine adj to -5
            Set dip switches 11-1 to a 1. Switch 38-1 and 38-2 to 1 duty cycle switches
            Swv19-7 to a 1
            Run about 100 test prints at 255
            Run auto gamma
            I still think with issue comes up when machine is ran with a very high coverage of a particular color and then subsequent jobs that follow have very little of that color or none at all. What I am not sure of is why the bias number gets stuck at 250.
