bizhub pro c500 adjustment help
  • qantas
    • Jul 2012
    • 23
    Hi mates,
    I just finished replacing U/L fixing roller on bizhub pro c500, been trying to follow the manual on mode 36, output image pattern test, but don't understand of entering the numeric key.
    how do you Guys calibrate the image or where to get procedure step by step.
    thanks
  • Mick01
    • Nov 2012
    • 362
    Re: bizhub pro c500 adjustment help
    Hi,
    Can you please explain what you are trying to achieve by outputting test patterns? You have replaced upper and lower fixing rollers, the only adjustment is fusing speed adjustment which is outlined in the service manual.
    FYI I use test pattern 1. You have to set the density of the colour you want to check in test pattern density setting.
    So for example if i want to check half tone of magenta in test pattern density setting i set Magenta density to 125, YCK to 0. then in test pattern output mode i set pattern number 1. This will output a sheet with Magenta at 125 density
    Hope this helps
