EP2120 Imaging unit fuse
  • ebm
    • Apr 2007
    • 183
    Does any one know the value of the fuse to reset the Imaging Unit counter on the EP2120 model?
    Thanks.
  • Rudi
    • Jun 2007
    • 251
    Why do you want to replace the fuse , if all you have to do is take out the toner bottle and short out pins 4&6 on pj3 on pwb a remember the mach must be off when you make the connection then switch it on while creating the short as soon as the mach starts to run or within about 5 sec break the short again.
    • nmfaxman
      • 1702
      Precision Roller PN m9970. $5.50
      • ebm
        • Apr 2007
        • 183
        I wanted to know if the EP2120 Imaging Unit fuse is the same as the fuse in the bizhub C450 fixing unit. Katun sells them $17.35/bag of 20. Thanks.
        • Mark B
          • Jul 2006
          • 153
          It is a Picko fuse I do not think there is a value.
          • cobiray
            Passing Duplication Xpert
            • Mar 2008
            • 1199
            The Katun p/n was 35010515. We had ordered a ton back in the day for some reason. Not sure of the new p/n if it might have changed with the merger.
            • Accentcp
              Old Tech
              • May 2008
              • 14
              1/16 Amp pico fuse
              • ebm
                • Apr 2007
                • 183
                FYI, the fuse Katun sells for rebuilding the EP2120 Imaging unit is the same as the fuse to reset the count on the Bizhub C450. Thanks.
