Hello, I have a code C-2861 with Konica C6500, help me!
Re: Hello, I have a code C-2861 with Konica C6500, help me!
Indicated gamma correction failure for the yellow. Means the patches made on transfer belt are not good. Run some test prints for yellow to start troubleshooting image defects.
Tech mode...
test print
set yellow and blue to 160
press copy at the top...
make sure you set to full color...
print a few 12x18 or 11x17 pages. see what you get.
yellow is the hardest color to figure out.
always easier to mix with blue and look for whats missing in the GREEN output, because yellow and blue make green. right.
would check your DV unit, make sure toner is moving though it ok, make sure the little 2 pin wire is plugged in up front, that shouldnt be the reason but i would check it anyway.
THEN POST PICS, of the output and the display - need to see where the consummables are at - seen belt age cause problems.
