G'day guys and gals,
I've got an issue with a Bizhub 211. What seems to be happening is, it is misfeeding from tray one. Tray 2 works a treat.
The first step we took was to replace that annoying spring loaded gear in the drivetrain at the back, but that didn't change anything. We replaced this part first because we've had that fail on 3 machines in a year. All the solenoids seem to work correctly, but it doesn't want to feed any paper.
I've had it with these machines. I was thinking that the Pawl (ref '19') on tray one isn't meshing with the pin (ref 'a') on the spring loaded gear. I can see that pin that is supposed to turn is turning.
The next step I was going to take was to replace the whole tray.
Has anyone else got any other ideas? Anything I've missed?
Cheers
Cheers
