C8000 test pattern for halftone of every colour
  • AB1984
    • Oct 2012
    • 64
    I knew which pattern it was once, but I've since forgotten, and now have gone back to pattern 53, and doing each colour individually. But it would be much easier to get them all output at once.
    A quick question, with hopefully a quick response,
    many thanks
    Last edited by AB1984; 08-06-2013, 10:25 AM. Reason: Couldn't see the whole title on the homepage
  • Mick01
    • Nov 2012
    • 362
    Re: C8000 test pattern for halftone of every colour
    Hi, I used to use test pattern 62. Input 8 prints and you get the 4 primaries, RGB and process pages. They are gradation pages. There is now version 60 firmware available that has a new test pattern 43. It gives solid pages, half tone pages RGB and process. Yu just input 12 pages and press start.
    • AB1984
      • Oct 2012
      • 64
      Excellent, thank you! Invaluable pattern there.
      I don't suppose anyone knows if there's a pattern that just does one halftone of each primary do they? If I want a quick check of the surface of the drums, or to spot corona problems that's all I need really. 8 sheets as opposed to 4 isn't really that much of a difference, but I just want to make my life easier and reduce waste.
      Cheers
