Konica bizhub c353 to print Local Received Fax time
  • steliogk
    • Aug 2025
    [Misc] Konica bizhub c353 to print Local Received Fax time
    Hi,
    Is there any way that the received fax would print the local time instead of the remote time from the sender? I am saying this because sometimes the sender's time is wrong.
    Thank you in advance
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Konica bizhub c353 to print Local Received Fax time
    if its in the fax header from the sender, nothing you can do about it.
    the activity report which you can print off the machine will have the correct time and date of reception.
