Need Firmware Imaging Toolkit 2006
+ More Options
Posts
  • gegione72
    • Aug 2013
    • 2
    [Misc] Need Firmware Imaging Toolkit 2006
    Hi, I need the Firmware Imaging Toolkit for rewrite firmware in an konicaminolta bizhub c250.
    I have try with cygwin but dont work , it dont write firmware to CF.
    In the konicaminolta site the imaging toolkit is not present, if someone can send it to my email.... gegione72@libero.it
    Thank you very much
  • JustManuals
    • Jan 2006
    • 9838
    Re: Need Firmware Imaging Toolkit 2006
    I have it but it isn't free. If interested, email me at Paul@justmanuals.com
    • Mick01
      • Nov 2012
      • 362
      Hi,
      Here you go
      • gegione72
        • Aug 2013
        • 2
        Thank you very much, i have rewriting firmware with toolkit , the c250 is rebirth.
        • dinesh818@gmail.com
          • Jun 2010
          • 8
          Originally posted by Mick01
          Hi,
          Here you go
          thankyou very much
          • Canon.Tech
            • Mar 2009
            • 335
            Can I have more that one machine model firmware on one card? or can I only keep one model on each card?
            • Synaux
              • Mar 2012
              • 1224
              In theory I would say probably, in practice, I never have and most likely never will.
              You can get cards on ebay for about $5-10 not really worth adding any mixup and risking a bad FW write no matter how remote in my opinion. Not sure if the Toolkit will write two FW to one card either.
              • Canon.Tech
                • Mar 2009
                • 335
                Thanks for your reply. Youโ€™re right CF cards are cheap. But how do I know what firmware series is the same, EG is C451 the same as what? C550,C650!?
                • emujo
                  • Jun 2009
                  • 3009
                  There are specific firmware versions for each of the MFPs that use those CF cards. You can either gather the 6 needed versions and keep them in a stack, or use one card and re-write it. Just be sure to NEVER write anything but the color MFP firmware to the card or it will never work again (w/o using a special program to write 0's to the card). BTW, with over 1000 posts, how do you manage to have all those red cards? Who did you piss off? EMujo
                  • Canon.Tech
                    • Mar 2009
                    • 335
                    Cheers, thanks for the info, so basically to be safe I needto store firmware for each machine on a separate SF card? But my question ishow can I tell what firmware I have, eg what machine is it for?
                    I got red marks for supplying manuals & Canon firmwarefor free, but I prefer red to green! (apparently this site is run by sponsorswho charge!)
                    So anyone reading this message me I can supply many service& parts manuals for free. (NEVER pay for them)
                    • Synaux
                      • Mar 2012
                      • 1224
                      Well, I simply hand-label all my CF cards the moment I write the FW to it to avoid any confusion.
                      Also, you can run the checksum to any FW to see if it will match in the Toolkit or cross-reference the checksum values with the pdf document that comes with the FW.
                      • mojtaba_5611
                        • May 2015
                        • 2
                        Hi,
                        Here you go
                        Tank you
                        very very very very much
                        • Ayodeji
                          Please how do I use the downloaded firmware on my C550. I don't see any USB port on the system
                          • bungapads
                            • May 2009
                            • 69
                            Thank you very much
                            Did you get the firmware to work? Is this the software that you use to reformat the harddrive? I have been locked out of my machine with a CE Password (no one knows what it is). I need to figure out how to reset the machine to factory settings? is this was you use to do that -...the firmware?
                            If so what is the process? I have downloaded the firmware tool, but I see no instructions? SOmething about a compact flash? where does this compact flash go? how do you reset the machine.
                            Help - ronaldbrilliant@yahoo.com if you can help.
                            • bungapads
                              • May 2009
                              • 69
                              I have to rewrite firmware for c550. I have the toolkit and a CF card (2 gig). I must be missing something. When I try to create the card with the toolkit it looks like everything is fine, but when I plug it into the machine it says that there is an error.
                              Questions
                              1. DO you have COMPLETE instructions on how to format the CF card?
                              2. Does the CF Card have to be 128 meg (or is that just what was available years ago?)
                              3. Any and all advice and details on how to do this reformatting would be greatly appreciated.
