PRO c6000l problem with yellow
  • igorp86
    • 16
    [Misc] PRO c6000l problem with yellow
    Hello I have problem with yellow developer on c6000l, after changing it was fine for cca 50.000 and again same problem, I changed dev. unit and developer, fine for some time and agan same problem ( yellow stripes in sub-scan diretion)
  • remati
    • 149
    Re: PRO c6000l problem with yellow
    .yes ...there it is a big problem.
    ..and I know that very well and do the same that you do...
    Try to adjust the doctor blade on the developing unit. (0,80mm) sometimes it helps
    • igorp86
      • 16
      Did it alredy, also changed transfer belt, drum, image correction unit...., but no luck, i'm like crazy over that. I have noticed that I have that problem only on 6000l, on PRESS 6000, 7000, 8000 is everything ok. For now i changed color balance for yellow on -8 ( for now, but I don't thing it will last for long )
