KM bizhub C352 error cod P-21
  • eugenionitza
    • Nov 2011
    • 18
    [Error Code] KM bizhub C352 error cod P-21
    Hi
    I have a problemwith a KM bizhub C352 copier gives me error P-21 (manual-Colorshift pattern test failure)
    When I print the paper is fullmagenta ( see photo attachments)
    when I give black copy no problem with magenta
    ichanged themagentaunitwithanother andthe same problem,
    please help
    thanks
    Eugen
  • tech51
    • 846
    Re: KM bizhub C352 error cod P-21
    I think the magenta write unit has failed. It's quite rare on this model, I have only had one fail ever but it gave exactly this fault.
    • eugenionitza
      • Nov 2011
      • 18
      I changed the magenta unit with another and same problem,
      it was 2 error code P-7 and P-21 but after restart dissapeared and remained only P-21
      thanks
      Eugen
        • 14568
        thanks
        Eugen
        Tech51 was talking about the printhead, not the imaging unit. Try swapping it with one of the other colours. If the problem follows, you know what to do.
        Hope this helps.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            unplug. clean the contacts and reconnect the flat ribbon cable at the MFP board side that goes to the print heads.
            Common problem - poor contact due to oxidisation of the pins.
            • eugenionitza
              • Nov 2011
              • 18
              thanks all , now it works
              I recleaned all sensors, all jacks cleaned everything contact
              problem solved ...
