windows 7 on a di 470 pi 4700e
  • brent
    • Nov 2008
    • 1214
    just wondering if this 4700e print controller will work with a operating system windows 7
    I couldn't find anything on kmbs. thought I would ask
    thanks
    brent
  • Hansoon
    • Sep 2007
    • 3389
    Re: windows 7 on a di 470 pi 4700e
    We have even the older Di-450 with Pi-5501 (similar) controller working with W7. I think it was with the W7 "onboard" driver or otherwise KonicaMinalta's "famous" universal driver.
    Hans
    • Gort
      Copier Demon
      • Oct 2011
      • 50
      I have used XP/2003 32 bit drivers on a Win 7 32 bit OS once. You will have to force the driver, as the older di models are no longer software supported.
      If you have a 64 bit OS you will have to use a generic PS/PCL driver or the KM universal driver.
      Sorry, I do not have a cat in my avatar.
      • brent
        • Nov 2008
        • 1214
        Nothing seemed to work. Have the pros here right now. How about hp 5 drivers?
        • Hansoon
          • Sep 2007
          • 3389
          Brent is it W7-32 or 64bit? Can you ping the controller?
          Hans
          • brent
            • Nov 2008
            • 1214
            I believe it is a 32 bit. Yes we can ping the machine. It sees it. Just won't prprinter can even pull up the web page. Just no print. Config page? Yes it prints. No jobs will. However
            • Hansoon
              • Sep 2007
              • 3389
              I have a Di-450 with Pi-5501 in the shop which is basically identical, even older. Now I'm at home but I'll try tomorrow and let you know. It has perhaps something to do with the port you are using.
              Hans
              • brent
                • Nov 2008
                • 1214
                I agree. We are using. Port 9100
