konica minolta bizhub 20
  • brent
    • Nov 2008
    • 1214
    faxing problem on a bizhub 20 mfp. it will print fine copy fine.. etc. it even faxes fine
    locally. when I try to long distance fax. it dies out and says 20 01 comm error
    thinking its in a line or switch. because it will local fax perfectly. and on one occasion
    it went to a long distance number. so the customer is confused..
    am I starting at the right avenue by calling the phone company and having them verify a proper connection?
    thanks
    brent
  • brent
    • Nov 2008
    • 1214
    Re: konica minolta bizhub 20
    also it spits out a transmission verification report and it states ng. poor line condition. out of memory
    just looking for some more insight on this code. thanks again yall
    brent
    • JR2ALTA
      • Feb 2010
      • 2033
      Phone company right track, but they are small enough to throw in your car and test and different one. At least then you can tell the phone company you tried two machines
      • brent
        • Nov 2008
        • 1214
        yes true. I have 5 in stock. but its just kind of confusing. I could just swap out and then retry
        brent
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          put machine "on hook" so you can hear it. then dial long distance number. You may hear an error message like "please enter long distance code to continue" or some other message and that will tell you the real problem.
          • brent
            • Nov 2008
            • 1214
            I have dialed with it on loud. It shakes hand starts to go. The. Codes out. So that is weweirdo may just take another machine to try it that way. It is logical but I think it's in a line. Or switch or somethjng
            brent
            • Mr Spock
              • Aug 2006
              • 2064
              make sure the "fax destination" is set for USA. Also Voip and DSL are not supported.
              • minimerlin
                • 851
                Can the distant fax comunicate with your unit? Try boosting the DB level on your fax?
                Please do not PM me without asking first.
                • antoruiz
                  thanks
                  brent
                  Got similar situation
                  got 3 units Konica Minolta Biz Hub 20 same model number
                  getting the "poor line quality - no enough memory"
                  others days are ok... but not everyday,
                  also check each of the settings and everyone are the same
                  I will try to escalate this issue internally, but if you have any tips .. please share
                  thank you.
