Konica Bizub 600 Jam at tray 2
  • brianho80
    • Sep 2009
    • 198
    Hi guys,
    I have a problem with this model at tray 2 only. It happen when only doing Duplex printing, and paper always stop between the feed roller and pick up roller in tray 2 which always caused jam code 1704.
    this means pre registration clutch (tray 2) has "on" and loop sensor at bypass not "on" within specific time.
    I tried to swap the paper feed unit between tray 1 or tray 3, problem remains the same.
    clutch, copper or gears at main body right side, I yet to check.
    anyone come across this problem before? appreciate if you could share.
    thank you.
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: Konica Bizub 600 Jam at tray 2
    i believe there is a bulletin for this issue and it involves adjusting the loop timing for tray 2.
    I'm operating off memory here, so don't shoot me
    • SmellsHot
      Head Tech
      • 512
      Take off bypass assy. There is a one way gear on there that drives the registration roller just before entrance into the main body. This will cause J17's. Also it's usually caked in toner too......
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • brianho80
        • Sep 2009
        • 198
        Hi There,
        just managed to settle this issued after perform so many adjustment ; replace of clutches and drive boards.
        Lastly, the reason is caused by tray 2 unit itself. Believe that, the cable to lift up the paper has loosen and somehow the plate will drop after few papers had been picked up.
        currently trying to fix back tray 2 unit and hope it can be repair.
