Bizhub 222 bottle rotation
  • wseyller
    • Sep 2012
    • 1129
    Customer had issue with installing toner and was getting message about waiting to refill toner. Key operator was gone when I arrive. Copier seems to print fine with no message. Bottle does turn but makes an usual noise. I uploaded a video. I can see the bottle raise up during rotation. I am taking some extra toner out there in the morning in case the bottle is the cause. Anyone seen this exactly. I looked at bottle and inside of the holder and didn't see anything odd but I didn't have anything to compare to. Bottle seems to fit ok.
    Sent from my Galaxy Nexus using Tapatalk 2
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Bizhub 222 bottle rotation
    Replacing the bottle should do the trick
    • krm
      • Aug 2009
      • 233
      Try new toner first. If noise continues they probably damaged the toner drive unit in the rear. That's a 2hr job - give or take. You can get the unit or just the housing as that's what gets damaged.
      • wseyller
        • Sep 2012
        • 1129
        Hoping toner because I know much of a pain it is to tear all that out. I will update the thread. Going 1st thing tomorrow morning.
        • wseyller
          • Sep 2012
          • 1129
          Toner bottle seems to fix it.
          • CompyTech
            Super Tech
            • Feb 2011
            • 706
            I had similar problem a couple weeks ago on 250 engine. They tried to put an old Konica 7115 (i think) toner in the unit. Glad that new bottle fixed it, and did not tear up the toner hopper unit.
            • SmellsHot
              Head Tech
              • 512
              The noise is actually a very common thing. If you think about how the toner is added you'll understand the noise. Looking closely at the toner bottle you see the groove and then a lip. Well the bottle rotates in the groove and then hits the lip(which helps shake the toner out of the hole) and causes the noise.
              Everyone has the right to be stupid. Some people just abuse this privelage more than others
