C284 FREEZE
  • selex
    • Sep 2009
    • 12
    C284 FREEZE
    I have this problem:
    when enter in sleep mode, sometimes the machine don't wake up in normal mode ! I must disconnect it..
    I try to upgrade fw and test ram-hdd
    Any ideas?
    Please help me!!
    Sorry for my english
  • GTgosu
    • Mar 2013
    • 19
    Re: C284 FREEZE
    I had a similar problem with a c253, try to check the problem for the network.
    Network Cable
    Slot Network
    Router / Switch
    • selex
      • Sep 2009
      • 12
      Re: C284 FREEZE
      i've checked but everything works perfectly
      • rrrohan
        • Sep 2011
        • 1976
        Re: C284 FREEZE
        i know previous models have had same problem and firmware update has fixed it.
        i wouldnt rule out Power Supply fault.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Re: C284 FREEZE
          what version firmware have you installed.
          This issue was resolved recently, and it IS firmware.
          • selex
            • Sep 2009
            • 12
            Re: C284 FREEZE
            here the version
            • JustManuals
              • Jan 2006
              • 9838
              Re: C284 FREEZE
              Paul@justmanuals.com
              • bizhub1
                • Sep 2008
                • 230
                Re: C284 FREEZE
                Just had a 552 do the exact same thing, turned out bad ram on map board.
                • kmcopytech
                  • Dec 2007
                  • 141
                  Re: C284 FREEZE
                  Upgrade special firmware GC1-68 or GD1-68,
                  It's correction sleep mode .
