Konica Minolta Bizhub C253 Magenta
  • Alex1
    • Oct 2012
    • 285
    I have a Kinica Minolta Bizhub C253 I'm doing magenta sky shots to see the density of the magenta imaging unit. I'm getting a lot of white spots in the prints any reason to the cause?
  • Blizzoo
    • Aug 2013
    • 608
    Re: Konica Minolta Bizhub C253 Magenta
    How is the state of the Mg IU?the chis is reseted?
    Check the electric contatcts of the unit,test with another one if you have the posibility.
    Could you post a scan of magenta pattern?
    • Alex1
      • Oct 2012
      • 285
      I see if I can figure out how to post with a scan lol I'm new at this!
      • cokwax
        • 50
        Type your post and scroll down to Attachments (under Additional Options), Click manage attachments. U can figure out the rest from there.
          • 14791
          Why are you doing skyshots to check density? Why not use service mode to do it?
          • wseyller
            • Sep 2012
            • 1129
            Same thing I was thinking. In service mode go to test mode then halftones.
            Sent from my Galaxy Nexus using Tapatalk 2
            • Hansoon
              • Sep 2007
              • 3389
              Agree, half tones say much more about the quality of components.
              Hans
              • Alex1
                • Oct 2012
                • 285
                Hans
                I did sky shot because I had a bit of trouble remembering to do half tones. I would agree it will give a better result.
