C4801 problem
  • tsewk
    • Jun 2013
    • 5
    C4801 problem
    Hi, my C224e have a failure issue.
    After unmount the HDD and perform format SSD,
    I use another new MFP board and Printer control board.
    after connecting the new HDD, C4801 shown
    And i check the service manual, It has no solution.
    Can anyone help me?
  • suomi
    • Oct 2008
    • 152
    Re: C4801 problem
    1.) MFP detects simultaneous replacement of multiple boards.
    2.) MFP detects unknown PRCB and unknown SSDB.
    3.) MFP detects unknown PRCB no engine data at SSDB.
    Reinstall the old PRCB and the old SSDB
    • Mr Spock
      Vulcan Inventor of Death
      • Aug 2006
      • 2064
      Re: C4801 problem
      4801 - MFP detects simultaneous replacement of multiple boards
      NOTE
      causes corruption of stored data.
      Note that the combination of the original MFP board and the used SSD board removed from another machine also causes the
      same problem.
      you will either need a certified tech or re-install original pwb's and try replacing one at a time.
      You must follow the directions in the manual or you will not recover the machine.
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        Re: C4801 problem
        They were very specific on this in class for this machine. Mr Spock is correct. Follow the instructions in the manual to a T or you have issues.
        "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
        • tsewk
          • Jun 2013
          • 5
          Re: C4801 problem
          There are 2 steps in the service manual:
          1: replacement the old printer control board
          2: call KMBT support
          I can't solve the problem after step 1.......
          Is there any solution other than call KMBT support?
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            Re: C4801 problem
            Follow the correct procedure on replacing the boards...if you do not follow the steps exactly as it says in the service manual you will have problems.
            • copy_wizz
              Re: C4801 problem
              Hi all, I have a similar problem but mine is a bit more complexe because while i tried mfp with ssd on other machine and then prcb but made a mistake didn't turn on the machine when i put back mfp board and now i have a machine with it's original boards but has a c 4801 error code. There is no posibillity of puting back ˝original˝ prcb because it is allready installed. Any idea on how to fix problem? Is there any tool for reseting prcb or that little board that recognises when a board is changed?
              • SmellsHot
                Head Tech
                • 512
                Re: C4801 problem
                If I'm not mistaken, isn't this the error that you leave alone and let the machine restart 3 times and then you do an "engine data backup"?
                Everyone has the right to be stupid. Some people just abuse this privelage more than others
                • copy_wizz
                  Re: C4801 problem
                  Nope, this is when you replace multiple boards at once. When you put a brand new mfp board then you let it restart 3 times ....
