when use duplexing , the 2nd page fly to touch the drum separater ( No Jam ) .i change the c.wire but still problem .Any ideal or setting for charging unit ? thanks
Bizhub 600 2nd side paper flying ( image blur )
Re: Bizhub 600 2nd side paper flying ( image blur )
Can you please clarify what you mean in regards to Charge? i am assuming you mean the separation corona wire, not the charge wire. Is this correct?
Most likely this is a paper curl issue, not machine issue, try loading the stock short edge feed and try. Try another stock in the machine. -
Most likely this is a paper curl issue, not machine issue, try loading the stock short edge feed and try. Try another stock in the machine.Comment
