its C451 again ... copying issue
  • konica7022
    • Nov 2008
    • 132
    hi guys
    bizhub c451 is giving following copy (its like half unfused toner on the paper)
    but print comes out fine ?
    and can some one pls send me a service manual for c451
  • konica7022
    • Nov 2008
    • 132
    Re: its C451 again ... copying issue
    ok now its in the print as well
    but its only the black color that seems too be effected
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      black imaging unit failure, for reasons mentioned a thousand times before.
      search the forum
      • konica7022
        • Nov 2008
        • 132
        search the forum
        thank you
        thats what i suspected, so i removed the black IU and saw same toner/dev!! rolling on the drum, cleaned it and slide it back in
        now its working fine again!
        except of the paper ejection gear!
        • Konicoz
          • Jun 2013
          • 62
          Cleaning excess Dev off the drum will only be a temporary fix - it will come back and will most certainly affect c/q, you will need to replace the unit. There is a mod bulletin for the k drum as well that you can find on the km site
          Hey what ya doing? - just screwing around.
