Konica 224 toner fit Olivetti mf222?
  • Olivetti man
    Hi
    i was wondering if Konica 224 toner fits mf222 as its the same machine and the toner is not chipped
    is the difference a lug that needs removing or are they the same
    please someone let me know
    • 14371
    Re: Konica 224 toner fit Olivetti mf222?
    I am sure the toners on the C224 are chipped. That doesn't mean they won't work. Just try it a and see for yourself.
    • Olivetti man
      We're are the chips located? Uhave looked inside the plastic handle and can't see anything
      The compatible toners are able to work in Konica,develop and olivetti models
      your help would be most appreciated
      • Olivetti man
        The toner is tn321
          • 14371
          On the KonMin models the chip is located on the black part of the cartridge.
          • Olivetti man
            Are the chips fuse able or just telling the machine it's a Konica or Olivetti toner?
              • 14371
              It tells the machine how much toner is left and colour. Maybe machine model as well, no sure
              • Olivetti man
                I will let you know tommorow
                going to see if the toners fit
                i have a bulk load of Konica 321 toners and a load of Olivetti machines mf222
                i am sure the chips are universal to Konica develop Olivetti but the end has a notch on that needs removing
