Bizhub c250
  • bebe.radescu
    • Jul 2012
    • 54
    Bizhub c250
    Km bizhub c250 transfer belt at it's life end, anyway, the transfer belt works just fine. I need to know if there's a chip or a way to reset it.
    Thanks!
  • SmellsHot
    Head Tech
    • 512
    Re: Bizhub c250
    Theres a fuse. Should be located on the left handle as you pull the tbelt out. Look for the contacts. two screws, e-clip and one tiny screw will remove the cover to the fuse....
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • emujo
      • Jun 2009
      • 3009
      Re: Bizhub c250
      FYI you must use the exact same fuse as original, if you don't you will blow PCRB and will need to be replaced. Might be prudent to just swap the x-fer belt with new one if you are not sure of what you are doing. Emujo
