bizhub 250 long warm up time
  • DOE
    • Mar 2010
    • 258
    i had a 250 i posted earlier on that had alot of problems. (c2557, c2211)i had a parts machine so i rebuilt it with problem copier. this one goes to ready to copy but only after it warms up for 5 min. i can tuen it off and right back on and its another 5 min. wait. the screen stays on the konica minolta screen for 5 min. then switches to ready to copy screen. when i try to make copy says i have wrong paper size and when i choose it freezes up and you cant do anything. need to get past the warm up problem so i can work on the other problems. any advise would be apreciated. the copier i used to rebuild did not have this problem nor did this machine when it worked.
    • 14754
    Re: bizhub 250 long warm up time
    It sounds like either the toner bottle is empty, or, it is set to DHCP and not connected to a network and it is waiting for an IP address.
    Set it to manual and put in an IP.
    Hope this helps.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • wseyller
        • Sep 2012
        • 1129
        I would try flashing a full firmware and doing a total reset. Unplug any accessories and any data cables to see if issue persist.
        Sent from my Galaxy Nexus using Tapatalk 2
