Bizhub c350 imaging unit -Message override
  • dmzfmz
    • Aug 2025
    Got a Bizhub c350 --After displaying REPLACE
    IMAGING UNIT SOON --the machine just stopped
    --says CHANGE IMAGING UNIT-
    Any techs know how to disable that message
    and allow machine to continue using that
    imaging unit without a chip reset (black)
    Thanks in Advance
  • ni311
    • May 2008
    • 658
    You cannot override the message.
    You have two choices:
    - buy a new unit
    - buy a chip resetter
    A new unit can be used once, but with a chip resetter you can reset an unlimited number of units.
    Konica Minolta Error Codes - Explanations and Solutions
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      You cannot reset the message but you can disable the lockout on the IU's. I would have the units replaced and ask your tech to disable the lockout for you on the service call.
      • redhotrob
        • 69
        Yes, the factory default is for the machines to stop when the image unit life has expired. In the service security mode this can be disabled.
        Stop,9
        • popcornpuppy
          • Jul 2008
          • 29
          once in tech rep mode press stop, 9 and set image units from "stop" to "no stop" on newer machines you need to press stop, 0, C once in tech mode
          • DarthAlbin
            I thought that feature didn't come out until the C450.
            Never mind. I forgot. Newer FW feature right?
            • deep
              • Jun 2008
              • 208
              Absolutely correct. Some features will be different depends on what category you machine is.
              Sometimes if a lot of customers feel unhappy on some unreasonable feature, the manufacturer will modified it.
              Kenny
              • Shayra
                Re: Just purchase a reset chip
                If you work for a dealer...Try contacting a wholesale distributor like Copylite for the chip. Each chip is priced below $20.
