Toner compatibility BIZHUB C550 - C552 - C454 - C554 - C654
  • daniel.vasiliev
    [Misc] Toner compatibility BIZHUB C550 - C552 - C454 - C554 - C654
    I own a C451 and C550, recently i came across some C554 toners, can i use them
    in C550.
    Also does anybody know if its the same toner from c5500/6500.
    Thanks.
  • dirtyfingers
    • Sep 2013
    • 35
    Re: Toner compatibility BIZHUB C550 - C552 - C454 - C554 - C654
    C451/C550 is not compatible with C454/C554
    C454 uses developer and toner in the bottle.
    It would be a big mistake to try it
    • daniel.vasiliev
      I knew that the developer is inside the IU, at least for the C451/550 is it different for the new line ?
      What about the C452/C552 and the pro line C5500/c6500, are the toners compatible with C451/C550 ?
      • stefanv
        • May 2010
        • 13
        Yes you can use the toner from c452 in c550...Just note the chips are different...It is only the black toner from c452 that has developer mix and not the colour toners
        • SERAFEIM
          • Dec 2005
          • 12
          I know that C6501 toner is compatible with C550 C451. I've tried three sets to now. just the engine continually show the toner that is finished
