C70hc+RU-509+FS-513, How to print 1200mm long paper???
  • kmcopytech
    • Dec 2007
    • 141
  • kalindd
    • Jun 2008
    • 192
    Re: C70hc+RU-509+FS-513, How to print 1200mm long paper???
    Basically you can't. Banner print is not supported with finishing options.
    However if you set the paper as 200gsm it will work, if you have fs-612, but I'm not sure whether this will work with your finisher and RU.
    Good luck.
    • Mick01
      • Nov 2012
      • 362
      Hi,
      your issue is the RU unit. You cannot output banners with that option installed.
