Bizhub C531 DHCP/IP settings locked
  • Darv
    • Sep 2013
    • 13
    Hi,
    I hope somebody can help me.
    I recently bought a second hand Bizhub C351 and have managed to reset the password but I'm having difficulty registering it on my network. I run a Windows based network and I suspect the printer is setup for Mac.
    I have printed out the Config files for the printer which are as follows:
    Server Info
    Password Enabled: Yes
    Memory (MB) 256
    Software: EFI Fiery System 6e
    Version: 1.1
    Disk Size (MB): 33276
    Free Disk Space (MB) 20680
    System ID: D19A20C79131B10
    Server Setup
    Server Name: X3ETY_EB7C
    Print Start Page: No
    Use Character Set: Macintosh
    Enable Printing Groups: Yes
    No Authentication and Account Printing: Disable
    Enable Printed Queue: Yes
    Jobs Saved in Printed Queue: 20
    Clear Each Scan Job: After 1 day
    Enable mailbox passwords Yes
    Preview While Processing: No
    Time Zone: London (GMT)
    Network Setup
    Port Setup
    Ethernet Setup
    Enable Ethernet Yes
    Ethernet Address: 00-E0-81-58-EB-7C
    Ethernet Speed: Auto Detect
    USB Port Setup
    Enable USB Port: Yes
    Port Timeout in Seconds 30
    Ignore EOF Character: Yes
    Protocol Setup
    Enable Apple Talk: Yes
    AppleTalk Zone: *
    Enable TCP/IP: Yes (Ethernet)
    Ethernet Setup
    Enable Auto IP Configuration: No
    IP Address: 192.168.142.101
    Subnet Mask: 255.255.255.0
    Get Gateway Address Automatically No
    Gateway Address: 192.168.142.253
    DNS Setup
    Enable DNS: No
    Security Setup
    IP Filtering: No
    IP Port Setup: No
    Enable IPX/SPX: No
    Service Setup
    Enable LPD: Yes
    Enable PServer: No
    Enable Windows Printing: Yes
    Server Comments:
    Workgroup or Domain: ARCHITYPE
    Use Automatic Configuration: No
    Use WINS Name Server: No
    Point and Print Drivers: PS
    Enable Web Services: Yes
    Enable IPP: Yes
    Enable Port 9100: Yes
    Port 9100 Queue: Print Queue
    Basically, I know nothing about setting up printers but I'm pretty technically minded and fairly proficient at networks etc. I'd like some advice on how to get this printer running on a Windows based system (assuming it is setup for use on Mac as above). I have tried to reconfigure the IP address on the IP settings page (Administrator setup) but it won't let me change anything - the IP settings are locked. DHCP is set to 'ON' but there is no 'OFF'?
    Any help greatly appreciated and I thank you for your time and effort up front!
    Regards,
    Darv
  • a4o7910
    • 27
    Factory default.pass Fiery.1
    • Avskrap
      Partner in crime
      • Jul 2011
      • 160
      Re: Bizhub C531 DHCP/IP settings locked
      Since the machine is fitted with a Fiery (external print controller), you don't set the network settings in the machine itself but on the Fiery controller. You do this by going to Controller Settings under the menu, the entering setup by scrolling down a step, entering the password stated above and entering Protocol -> Ethernet setup.
      The Fiery is the only thing connected directly to the network and gives the machine an IP adress via DCHP.
