bizhub 601 copies then just keeps running.
  • brent
    • Nov 2008
    • 1214
    thats the best I can describe. it is running for a couple minutes. then it jams in the sync section. am I looking at just a clutch? weird that it doesnt' imediately time out. finisher is running machine as well
    any thoughts?
    it did show jams in tray one. justreplaced all the feed tires and clutches as well
    thanks
    brent
  • brent
    • Nov 2008
    • 1214
    Re: bizhub 601 copies then just keeps running.
    its a strange problem. so I just went and replaced sync cl and still the same.
    it is a tray one problem. paper feed tray 2 is just fine. so I am going to rebuild tray one
    and go from there. it has new feed tires and a feed clutch. I must have missed something
    brent
    • SmellsHot
      Head Tech
      • 512
      So is it just running, but no copies come out and then eventually it registers a jam?
      Everyone has the right to be stupid. Some people just abuse this privelage more than others
      • ivovb
        • 695
        Get latest FW and check sensors on the paper path. Is it the same problem using any of the paper sources (try manual bypass) and paper formats?
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • fixthecopier
          ALIEN OVERLORD
          • 4713
          I had an ongoing problem on a 600 that would give false 201 codes. Swapped everything, reloaded firmware and changed wire harness for all the trays. Brought machine in and then district rep shows up and says "If you would have used THIS firmware, that I didn't tell you about, it would have been fixed" He was an ass.
          But on your problem, I would think firmware and then control board.
          • brent
            • Nov 2008
            • 1214
            [i It is working perfectly out of tray two. That makes me think tray one is the culprit
            =fixthecopier;379546]I had an ongoing problem on a 600 that would give false 201 codes. Swapped everything, reloaded firmware and changed wire harness for all the trays. Brought machine in and then district rep shows up and says "If you would have used THIS firmware, that I didn't tell you about, it would have been fixed" He was an ass.
            But on your problem, I would think firmware and then control board.[/QUOTE]
            • fixthecopier
              ALIEN OVERLORD
              • 4713
              Seems like it thinks there will be another sheet coming. I would swap feed assembly between tray 1 and 2, then behind the conveyance tray above tray 2 are 2 photocells, check and or change them.
                • 14943
                It may help if we had the relevant jam code or codes associated with the problem.
                • brent
                  • Nov 2008
                  • 1214
                  I did swap them fix. But I used a lower feed assy. I got it working for the day. Going to hit it again on monday
                  • methogod
                    • Dec 2008
                    • 922
                    this happens with the 920 series sometimes... never been able to fix it with firmware.... but on the 920 its just run's until a time out occurs then usually a registration jam code or sc code...
                    forget the codes...
                    I know its usually out of the LCT and the fix has to do with exit senors to the finisher or the entry sensory from the lct to the main body.
                    BEST BET to remove finisher and see if you can still duplicate it...
                    i know that if you run face down and it happens, try running face up....
                    if you can make it go away, you can isolate where this is happening...
                    also whats the meter? all supplies current?
                    • pepper38_cnd
                      Field Service Manager
                      • Aug 2005
                      • 1075
                      Try changing the toner control board.
                      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                      Now into Ip TV KODI Boxes
                      • brent
                        • Nov 2008
                        • 1214
                        I do not recall the jam code. I am pretty sure it was triggering a jam code from drawer one. The confusing part is tray 2 is absolutely fine. So before I do any firmware or removing finisher I am going to work in tray one feed. It already has new clutch and swapped a feed unit It's logical. And I only happened upon it when trying tray 2. Tray one is a no go. But it is confusing it is exactly the same way. Stuck in the sync section. I will advise when I fix it tomorrow
                        brent
                          • 14943
                          brent
                          The only section that tray one uses and tray two doesn't use is the little transport section above tray two. That is why the jam code is important. There are sensors and clutches that run this section. So any of the tray one jam codes can actually point towards the "horizontal conveyance section".
                          Hope this helps.
                          • fixthecopier
                            ALIEN OVERLORD
                            • 4713
                            Those 2 photocells I mentioned behind the conveyance tray will make the machine do strange things if they are bad or out of place. I had a case where the machine would just accept jobs and not print because the photocell was bad and the machine thought the tray was not seated, but would not tell me that, just like a bad or dirty TCB. Also, the drive train for tray 1 is kind of separate from the others til it gets to the right side door. I think I have had to change those clutches for that conveyance tray before, so you may want to take a pair with you. Have to remove right side cover and horizontal transport, then it is easy to get to.
                            Your problem sounds familiar, but I was remembering a stuck actuator on the exit of finisher, and it would do it from all trays.
                            • brent
                              • Nov 2008
                              • 1214
                              the code is 1101 and 1102 tray 1 jam. I replaced the feeding section out of a working machine.
                              both clutches in that feed tray 1 it still jams and stops the copy in the sync section
                              paper is not stuck in the little transport that sits over tray 2
                              so it is certainly tray 1. I may take a whole tray and replace and see if that fixes it. everything I have done thus far is not working. unless I am missing something
                              brent
